Activity Forums Adobe After Effects linear workspace compositing output dpx
  • linear workspace compositing output dpx
    Posted by Sim Xiaozhang on December 10, 2013 at 2:34 am
    Hi guys. I am working on a project using linear workspace in AE. Needed to composing some cg plane over a normal mov footage. Output need to be dpx seq.
    Project setting is 32bit, working space sRGB. checked the linearize working space.
    Put an adjustment layer on top, cineon convertor lin to log
    so when everything is done i output the project to dpx seq. Problem is the output looks darker than what i have seen in my comp.
    Tested the final output by importing it in a new comp with no working space n applying a cineon convertor log to lin.
    Am i doing anything wrong here? This used to work when i am working with dpx seq as my backplate. Is there anything i need to set to my mov footage?
    Pls help.
    Sim Xiaozhang replied 12 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
