Activity Forums Adobe After Effects Expressions Linear interpolation to hold interpolation expression
  • Linear interpolation to hold interpolation expression
    Posted by Ale Elizondo on September 25, 2014 at 4:50 pm
    Hello community!
    I am trying use the interpolation expression: linear(t, tMin, tMax, value1, value2), but I want that the result in the property be hold interpolation instead of linear interpolation, to obtain only the highest and lowest values without any interpolation between values.
    I hope you can help me.
    Dan Ebberts
    replied 11 years, 12 months ago
    2 Members · 5 Replies
  • Dan Ebberts
    September 25, 2014 at 5:19 pm
    Maybe like this:
    if (t < (tMin+tMax)/2) value1 else value2
    Dan
  • Ale Elizondo
    September 25, 2014 at 6:24 pm
    Thanks for your response Dan.
    I use this as follows:
    t=thisComp.layer(“ojo 2”).transform.scale[1];
    if (t < (0+100)/2) 100 else 0
    this on Opacity property, but there are some problems :/
    my idea is to invert the values ​​and this works but until the value is less than 50, I guess this is why the division is by 2, I want the change to happen until it reached the maximum or minimum value
  • Dan Ebberts
    September 25, 2014 at 6:30 pm
    OK, so the output changes when the value becomes greater than the maximum value and doesn’t change back until it becomes less than the minimum value, is that correct? If so, that’s a much more complex expression, which will have to examine previous frames to see how input got to its current value.
    Dan
  • Ale Elizondo
    September 25, 2014 at 6:49 pm
    For example when the Scale of the first object is 100 the opacity of second object is 0 that is correct but when the scale changes to 99 the opacity changes to 100 this doesn’t work for what I want. This question was for properties of one dimension, I would like make it too with an interpolation between property of two dimension to one dimension, how from scale to opacity, I guess this will be more difficult XD.
    Thanks for review this Dan
  • Dan Ebberts
    September 25, 2014 at 7:19 pm
    Sorry–I’m a little lost. If there’s a one-to-one correspondence between input values and output values, that’s easy. If the output value depends at all on the history of the input value, that’s a different story. I can’t tell which case we’re talking about here.
    Dan
