Activity Forums Adobe After Effects Expressions Linear expression to control start/end keyframe (Essential Graphics problem)
  • Linear expression to control start/end keyframe (Essential Graphics problem)
    Posted by Sem Brys on April 23, 2019 at 3:47 pm
    Hello, I have a question regarding the linear expression I am using.
    This expression is used to control the start and end range of a basic text animation ( ‘typewriter’ in Animation Presets).
    The idea is to have a template where I can choose the start and end frame of the text coming on screen.
    It works just fine in the composition itself, but when I use it as an essential graphics layer in another composition the animation always starts at the in point of the layer, regardless of the numbers I input in the essential graphics panel.
    I’m working on AE CC v15.1.2
    Here is a link to a screenshot, if that would help to clarify the problem.
    https://cincopa.com/~A4IA-RbWMFlu!AEODePzHPqml
    And the code I’m using:
    StartPoint = effect("START")("Slider")/25;
    EndPoint = effect("END")("Slider")/25;
    if (time<=StartPoint){0;} else if(time>=EndPoint){100;}
    else { linear(time, StartPoint, EndPoint,0,100); }
    Sem Brys replied 7 years, 5 months ago 1 Member · 1 Reply
  • Sem Brys
    April 24, 2019 at 7:37 am
    Hmm, very strange. After giving up yesterday and reopening the project today the problem seems fixed…
