Activity Forums VEGAS Pro Line Spacing
  • Line Spacing
    Posted by John Mccready on November 3, 2009 at 2:10 pm
    Hi All:
    Is there an easy fix to to control line spacing in Video Vegas 8.0? I checked out the Line Spacing category in the Help menu under Layout Controls and it says;
    Line spacing When you have multiline text blocks, drag this slider to increase or decrease the space between lines.
    Can you please inform me where to find the “slider”? I tried to search Help for it but could not find it. I also read that Vegas 8.0 has a new Titler feature but could not find out anything in Help about it either.
    Thanks, John
    Mike Kujbida replied 16 years, 10 months ago 2 Members · 2 Replies
  • Mike Kujbida
    November 3, 2009 at 2:16 pm
    The “slider” you want is actually the Leading slider and is in the Properties tab of a Generated Media event.
  • Mike Kujbida
    November 3, 2009 at 2:39 pm
    I forgot to mention that the new titler is called the ProType Titler.
    The online help menu has a section on it called “Using the ProType Titler” that you can look through.
    There are also several YouTube tutorials on using it.
    I played with it a few times when it first came out and haven’t looked at it since.
