Activity Forums Apple Final Cut Pro Legacy Line out is one frame out of synch with picture
  • Line out is one frame out of synch with picture
    Posted by David Page on January 30, 2014 at 2:39 pm
    Using line out from the back of the tower to feed external speakers it appears my synch is a frame or so off … time code proves it isn’t, but it looks that way.I am feeding two apple computer monitors. I suspect there is a common fix for this. What is it? And If I want to ad a TV monitor as well, how do I do that?
    Thnx.
    David Page replied 12 years, 7 months ago 2 Members · 3 Replies
  • Shane Ross
    January 30, 2014 at 5:30 pm
    IN the SYSTEM SETTINGS under the FINAL CUT PRO menu, click on the PLAYBACK SETTINGS tab, and you can adjust the FRAME OFFSET there.
    Shane
    Little Frog Post
  • Shane Ross
    January 30, 2014 at 5:31 pm
    As for connecting this to a TV monitor…you need a video IO device. AJA.com, Decklink.com, Matrox.com offer solutions. Cheapest are from decklink.
    Shane
    Little Frog Post
  • David Page
    January 30, 2014 at 5:54 pm
    thank u
    ps i enjoy your blog
