Activity › Forums › Adobe After Effects › Line drawn 3D shapes
  • Line drawn 3D shapes
    Posted by Casey Longden on August 3, 2015 at 10:14 am
    First post so I hope I’m in the right place – if not, feel free to point me elsewhere.
    How would I go about making 3D shapes with a line drawn effect that can be rotated etc. (as seen in the attached screenshot taken from this video by Impactist – https://vimeo.com/446384)?
    The colour fill isn’t necessary but it would be interesting to learn how that is done too.
    Thanks.
    Casey
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Casey Longden replied 11 years, 1 month ago 2 Members · 6 Replies
  • Stephen Smith
    August 5, 2015 at 5:16 pm
    My guess is that it was built in a 3D program. If you wanted to build it in After Effects it can be done but will take longer. You will have to create a rectangle and check the 3D space check box. Make sure you only have the ouline and not the fill. Then create a line the length as one side of the rectangle. Then using the position and rotation you will have to build a triangle. You can parent all of them to a Null if you want to rotate or move the whole 3D triangle. Hope this made some sense. Best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
  • Casey Longden
    August 5, 2015 at 7:10 pm
    Thanks for taking the time to reply, Stephen. Your AE workaround does make sense to me but perhaps C4D Lite would be a good starting point instead. Time to get learning!
  • Stephen Smith
    August 5, 2015 at 7:12 pm
    If you do c4d you might want to check out tutorials that do toon shader looks like this one:
    https://vimeo.com/96262267
    Stephen Smith
  • Casey Longden
    August 5, 2015 at 7:45 pm
    That’s just what I’m after – 2D ‘toon’ style colour on 3D shapes. Thank you.
  • Stephen Smith
    August 5, 2015 at 7:48 pm
    Cool, best of luck. Show us your stuff when you have it done.
    Stephen Smith
  • Casey Longden
    August 5, 2015 at 7:49 pm
    Sure – always good to have some critique 🙂
