Activity Forums Adobe After Effects limiting rotations
  • limiting rotations
    Posted by Matt Howarth on August 24, 2017 at 3:14 pm
    hi all
    I’m attempting to make an automated pie chart, where you have as many segments as you like and the final segment fits into the remaining space perfectly. I have it working apart from the final segment. I am trying to use the rotation of the previous layer (combined with it’s own segment angle) to drive the final segment angle, but because of the way I have set up the previous segments, the penultimate angle can be several times 360 + the angle I want to use. For example:
    4x+240.0°
    in this instance how to I get rid of the 4x?
    I have tried writing a while loop to say while the angle is greater than 360, subtract 360, but it doesn’t seem to regard the 4x+240.0° as being more than 360.
    Any pointers would be gratefully received.
    cheers
    Matt
    Visual tinkerer and easily distracted admirer of all things shiny! – writer – animator – digital artist
    Matt Howarth replied 9 years, 1 month ago 3 Members · 3 Replies
  • Chris Wright
    August 24, 2017 at 6:36 pm
    the good ‘ol trig expression pie chart i made a billion years ago
    https://forums.creativecow.net/thread/227/17128#17144
  • Walter Soyka
    August 25, 2017 at 3:04 pm
    [Matt Howarth] “I have tried writing a while loop to say while the angle is greater than 360, subtract 360, but it doesn’t seem to regard the 4x+240.0° as being more than 360.”
    Use the modulo operation [link], which returns the remainder after a division operation. 4x+240.0° (or 1680°) modulo 360 equals 240.
    Here’s sample code:
    x = thisComp.layer("LAYER NAME").transform.rotation % 360;
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Matt Howarth
    August 26, 2017 at 10:38 am
    thanks Walter,
    that was exactly what I was after : )
    cheers
    Matt
