Activity › Forums › Sony Cameras › Limitations of SxS-1 Cards
  • Limitations of SxS-1 Cards
    Posted by Michael Moser on October 28, 2010 at 11:12 pm
    What are the limitations of the 64g SxS-1 cards as opposed to the SxS Pro cards. I don’t believe SxS Pro cards are available in 64g, are they?
    Michael Moser
    George Yousko replied 15 years, 10 months ago 7 Members · 9 Replies
  • 9 Replies
  • Les Wilson
    October 28, 2010 at 11:32 pm
    The SxS technology, like any SSD based technology, lasts but a certain amount of time as measured by reading, writing, formatting etc. According to Sony the SxS-1 won’t last as long as the Pro model. The statistic I hear the most is if you used it every day for 8 hours a day, it would “only” last 5 year. There is some kind of “gas gauge” that shows the remaining “life”. I haven’t seen them in 64GB.
  • Ian Cook
    October 28, 2010 at 11:44 pm
    Hi Michael,
    The main difference between the two is lifespan. The SxS-1s will go for approx 10,000 read/write cycles; the SxS-Pros will go up to 100,000 read/write cycles.
    Also, The EX-1 needs firmware 1.20 to support SxS-1. The EX-3 needs v 1.10. PMW-350, PMW-320, PMW-500 + PMW-EX1R are newer models and don’t need any upgrades for SxS-1 support.
    Best,
    Ian
  • Michael Moser
    October 29, 2010 at 12:40 am
    Thanks…I didn’t realize it was an order of magnitude.
    Does anyone know what the price of the 64G Pro cards will be?
    Best,
    Mike
  • Steve Wargo
    October 29, 2010 at 7:06 am
    I was quoted the following
    1
    SBS-32G1A
    $622.08
    1
    SBS-64G1A
    $935.06
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
    Sony HDCAM F-900 & HDW-2000/1 deck
    5 Final Cut (not quite PRO) systems
    Sony HVR-M25 HDV deck
    2-Sony EX-1 HD .
    Ask me how to Market Yourself using Send Out Cards
  • Clint Fleckenstein
    October 29, 2010 at 1:49 pm
    What’s nice is that they have been getting significantly cheaper. If I remember correctly, you can get a 32GB SxS Pro for what an 8GB card cost when they first came out…
    Cf
  • Steve Wargo
    October 30, 2010 at 8:30 am
    My first 8Gb cards were around $500 each. However, compare that with the original price of P2, about $1000 a Gig.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
    2-Sony EX-1 HD .
  • George Yousko
    November 2, 2010 at 2:48 am
    Ian,
    I purchased two of the SXS-1 cards. The dealer stated that the life span was approx 1500 read/write cycles – 5 years of daily usage (per Sony) which is great. But your figure of 10,000 is even better. Is that in fact the true figure? Dramatic difference.
  • Bob Cole
    November 5, 2010 at 5:17 pm
    re life span: How do you know when the gauge is getting close to empty? I understand that there is a “gas gauge,” but that would require you to keep running some utility. Or do you know when the card starts to fail on recording/playback?
    Or, is this a legal-department mandate — a theoretical limit which nobody has yet reached in the real world?
    Bob C
  • George Yousko
    November 5, 2010 at 6:03 pm
    Greetings Bob,
    The “remaining life meter” can be found by going thru the status menu – button on top of the camera and of course having a SxS-1 card in the camera. Mine currently is showing 100% but then this card has had only one pass. Not by the camera currently but believe it to be on page 2 or 3. Hope this clarifies things.
    Cheers!
