Activity Forums Adobe Premiere Pro Limit to clips in the source monitor
  • Limit to clips in the source monitor
    Posted by Damian Bartolacci on February 2, 2013 at 3:48 pm
    Hello everyone! I was hoping someone would have an answer for this or perhaps a workaround of some sort. I recently moved to adobe premiere and love many things about it. However, one key feature I’ve not been able to find is a way to cycle through all of my clips using only the keyboard.
    Now, there is a custom keyboard short cut set up for “open in source monitor” which has alowed me to select my clips and open them in the source monitor. This is extremely convenient. But here’s where it gets interesting. The source monitor is only limited to 51 clips. I have many more than that which need to be cycled through.
    My question is: Is there a way to maximize the number of source monitor clips, or is there a work around to be able to use the shortcut keys to cycle through ALL of your clips and perform standard in and out edits using the J K and L keys?
    Thanks so much!
    Damian Bartolacci replied 13 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
