Activity › Forums › Avid Media Composer › Limit of clips and sequences in a single project ?
  • Limit of clips and sequences in a single project ?
    Posted by Christopher Tay on January 4, 2008 at 2:57 pm
    Is there a limit to the number of clips and sequences that you can have in a single project on either an Avid Xpress or Adrenaline system ?
    -chrispy
    Bouke Vahl replied 18 years, 9 months ago 3 Members · 2 Replies
  • Michael Hancock
    January 4, 2008 at 3:56 pm
    To my knowledge, no. There are limits to how many titles you can have in a bin (99) or 999 clips (I think), but you can just make a new bin and keep adding to them.
    Regarding sequences–the more complex your sequences are and the more of them you have in a bin the more memory Avid will hog. Keep only 1 or 2 sequences to a bin and you should be able to make as many as you want.
    Michael.
  • Bouke Vahl
    January 5, 2008 at 1:01 pm
    that’s a bit conservative.
    Depending on the complexity of the sequences, you can have way more. I keep about 15 long form piece sequences in one bin.
    As for the amount of clips you can have in a bin, remember that there are more items in a bin than you might see.
    If you have a bin with just one sequence, Avid also stores all used clips in that bin. That will add up.
    I once did a piece with a few thousand imported still images in it, and that brought Avid down. (each still had a reel name assigned.) Chopping up the sequence in two made it workable again.
    Biggest gotcha is too large mediadrives. A MXF or OMF folder can only have about 10.000 of files. If you have a lot of (audio) renders and you use the same media drive/folder for multiple projects, you’re heading for trouble.
    So partition your harddrives and only mount the ones you need, keeping the partitions reasonable small (like a few hundred gigs)
    Bouke
    http://www.videoToolShed.com
    smart tools for video pro’s
