Activity Forums Maxon Cinema 4D Limit dynamic clones movement to one axis
  • Limit dynamic clones movement to one axis
    Posted by Arthur Reis on September 13, 2018 at 10:59 pm
    Hi folks!
    I’ve been trying to achieve this effect
    https://www.instagram.com/p/BRxoMUPFbI1/?utm_source=ig_web_copy_link
    in cinema 4d. I created a cube array using a cloner and set a dynamics tag for both the cloner and for the object beneath them that should push the cubes up.
    I set the follow rotation to 100 so the cubes stay oriented upwards.
    The problem I’ve encountered is that the object beneath is pushing the cubes to all directions, but I want them to only move in the Y axis so they stay aligned like in the video.
    I tried setting up a connector on slider mode but it will only affect one cube, not all the clones.
    If anyone has any idea to get this effect working procedurally, I’d be very thankful.
    Cheers!
    Arthur Reis replied 7 years, 11 months ago 2 Members · 2 Replies
  • Brian Jones
    September 14, 2018 at 2:30 am
    you can clone connectors (and springs) by putting the connector rig into a null which goes into the cloner like this
    12716_clonedconnectorssprings.c4d.zip
    this rig has a slider to restrict the clones in one direction and a spring to keep the clones from bouncing too high when the ball moves through (try disabling or removing the spring) – there’s more than one way to damp the motion but the spring works well.
  • Arthur Reis
    September 14, 2018 at 5:50 pm
    That’s exactly what I was looking for. Clever use of the spring to damp the motion.
    Thanks a lot!
