Activity › Forums › Adobe Premiere Pro › like riding on square wheels
Posted by Norman Frizzle on January 27, 2006 at 6:29 amWhy is rendering and MPG compression so slow? And why does the MPG compressor apparently ignore the rendering and do it all from scratch?
Craig Howard replied 20 years, 8 months ago 5 Members · 5 Replies -
Mike Velte
January 27, 2006 at 12:13 pmEncoder settings influence speed…2 pass VBR is twice as slow as 1 pass CBR. Setting the Image Quality slider to 50 will increase speed greatly…almost realtime ona 3.0 P4.
Using Preview files as a source for Mpeg encoding would cause a generational loss.
Steven L. gotz
January 27, 2006 at 3:15 pmIf you have already rendered your project fro preview, then you might be willing to accept that generational loss. SO export a DV-AVI (should be very quick) and then put that on a sequence and export to MPEG. Should save one heck of a lot of time, but will have a tiny bit of loss. More than tiny if your text has not been optimized for the DV codec. But it will be fast.
Steven
http://www.stevengotz.com -
Norman Frizzle
January 27, 2006 at 6:30 pmI do want the quality. I just don’t understand why it is so strikingly much slower than in previous editions of Premiere Pro. Like 40 minutes to transcode an under one minute sequence of 3 video tracks!
Mike Cohen
January 27, 2006 at 7:05 pmIf I am doing a CD project which involves MPEG videos, chances are there are a number of them. In that case I export each sequence or portion of a sequence as an AVI, then use the batch feature in Squeeze of Premiere 6.5 to render the MPEGs.
Why Adobe got rid of the batch utility is beyond me – it is very useful. -
Craig Howard
January 27, 2006 at 7:11 pm40 minutes for 1 minute of source is far too long and there is a problem somewhere. I would expect that to be about a 3-5 minute process.
I always out put an avi submaster before encoding.Saves time and allows me to check each stage of the process.
BTW: Faster mpeg encoding is achieveable with the standalone MainConcept Encoder. I use this sometimes – especially if I need to Batch encode some avis. It can also batch encode multiple avis into one MPEG stream. This can be very useful.
