Activity Forums Maxon Cinema 4D Lightwall – Not all cloned lights are lit
  • Lightwall – Not all cloned lights are lit
    Posted by David Biederbeck on September 7, 2011 at 6:13 pm
    I have some spot lights cloned to a plane to make a pseudo “lightwall” The problem is that it is only lighting some of the spots like there is a map on it, but I can’t figure out why.
    Any thoughts?
    Reference
    Hierarchy
    Cloner
    Light 1
    light 2
    Brian Jones replied 14 years, 11 months ago 3 Members · 5 Replies
  • Brian Jones
    September 8, 2011 at 3:20 am
    try offsetting the cloned lights a bit forward of the plane
  • David Biederbeck
    September 8, 2011 at 5:40 pm
    Didn’t work. I just exported a compositing file, turned off the illumination here, and used optical flares in AE
  • Juan Hernandez
    September 26, 2011 at 11:25 am
    I am having the same problem. Have you found out a solution in C4D? I see you just went with using optical flairs but did you go back to figure out why some lights in the C4D scene didnt light up?
  • David Biederbeck
    September 26, 2011 at 4:07 pm
    nope, no sollution, and I literally checked or adjusted every setting. I also threw the lights into the cloner by them selves, and with other lights, strange. I got r13 last week so hopefully it is fixed there.
  • Brian Jones
    September 26, 2011 at 7:11 pm
    there wasn’t anything I saw in the pics you posted, without seeing the scene file itself I couldn’t guess myself.
