Activity › Forums › Maxon Cinema 4D › Lights as visible objects, and attaching them to tracers
  • Lights as visible objects, and attaching them to tracers
    Posted by Jon Lewis on May 23, 2007 at 12:17 am
    What is the best way to only see a light as a visible object, like a point light or beacon, then is it possible to attach that light to a moving object. Taking that a step further, can you attach that light to a set of tracers in mograph?
    Adam Trachtenberg replied 19 years, 4 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    May 23, 2007 at 3:25 am
    IMO the best way is to turn off illumination and turn on lens flare. You can make a light the child of an animated object so it will move along with it. You can also clone lights for use with Tracer.
