Activity › Forums › Adobe Premiere Pro › Lightroom to Premiere Metadata Workflow
Posted by Andy Baumgartner on April 9, 2014 at 6:02 pmHi, I tag all my videos along with my photos in Lightroom. Is there any workflow for using this metadata to filter videos in Premiere Pro?
Andy Baumgartner replied 12 years, 4 months ago 2 Members · 3 Replies -
Angelo Lorenzo
April 9, 2014 at 6:20 pmWhich XMP fields are you using?
Angelo LorenzoNeed to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter -
Andy Baumgartner
April 13, 2014 at 9:35 pmHi, Angelo. I’m not using any XMP fields yet, I can’t find a way to export video metadata from Lightroom.
I guess there are 2 parts to my question:
1. How to get video metadata out of Lightroom
2. How to associate this metadata with PremiereThanks!
Andy Baumgartner
May 5, 2014 at 9:22 pmHi, I found a workaround for this issue using keywords in the file name. It only works for a limited amount of keywords however.
If you go to export your videos under “File Naming” > “Rename To:” and then click “Custom Setting” there is an option to write the keywords to the file name. Then you can search by filename in Premiere. If you have too many tags or your file path is too long the export will fail however.
