Activity Forums VEGAS Pro Lightroom-esque Color Correction in Vegas Studio Platinum
  • Lightroom-esque Color Correction in Vegas Studio Platinum
    Posted by Tyler Murry on April 28, 2013 at 3:25 am
    I am new to color correction in Sony Vegas, but do have some experience balancing the colors in my photos with Lightroom/Camera Raw. Lightroom really gives you powerful control over the colors in the photos you take. However, I am looking for a good way to replicate that control within Vegas Studio Platinum (9.0).
    Perhaps I’m spoiled by Lightroom, but with anything I’ve tried in Vegas, I feel like I’m guessing quite a bit or it’s more of a manual process than I thought.
    Does anyone know of a great way to produce the same effects (clarity, vibrance, recover etc) in Vegas?
    Tyler
    Bob Peterson replied 13 years, 4 months ago 3 Members · 2 Replies
  • John Rofrano
    April 28, 2013 at 12:04 pm
    [Tyler Murry] “Perhaps I’m spoiled by Lightroom, but with anything I’ve tried in Vegas, I feel like I’m guessing quite a bit or it’s more of a manual process than I thought.”
    You are spoiled by Lightroom and video does not respond like Camera RAW so you simply don’t have enough information in the data stream to do some of those things.
    In Vegas Pro it’s a manual process. The Levels filter will allow you to control your luminece, the Color Curves filter will give you control over contrast and gamma curve, and the Color Corrector filter will let you adjust colors to correct your balance. Those three filters applied in that order should get you close to what you want but you have to know what you are doing; there are no “magic” controls that do things for you.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Bob Peterson
    April 29, 2013 at 5:42 am
    I have to disagree a bit here. The color corrector will do a pretty good job of white balancing the video image IF you can find white, neutral gray, and black in the image. That seems to be what the three color wheels are aimed at. Beyond that, they are not really precise enough to do good color correction.
    Color curves are much more useful, but you need to think carefully about what you are doing and clearly understand how complementary colors work. The biggest problem is that Vegas does not give you any information about where a particular instance of color in the image lies on the color curve. I have started to have some success by using Vegas’s ability to place a snapshot of the image on the clipboard. I can then bring that image into Photoshop, and Photoshop will tell me where specific points lie on the color curve (i.e. by using a color curve in Photoshop). Using that information, I use the red, green, and blue curves in Vegas to make the color correction. For example, if I have a yellow caste in a portion of the video image, I can reduce the yellow (and the luminance) by bending the red and green curves down at the appropriate point on the curve, OR I can reduce the yellow while increasing luminance by bending the blue curve up at the appropriate point. The ability to center the adjustment at the correct point on the curve and shape the curve gives much better results than I have been able to achieve with the color corrector. You can, of course, also selectively cut or boost luminance for a specific tonal area using a curve. It is not quite as easy as using a slider to, for example, fill shadows, but it can still be done.
