Activity › Forums › Lighting Design › lighting up a 16 feet x 16 feet room for video recording
  • lighting up a 16 feet x 16 feet room for video recording
    Posted by Temitope Amoo on September 29, 2012 at 4:44 pm
    Hello. I need help with lighting a 16×16 room with 2 kino flo 4banks and a 300w par can as backlight. Settled for this because the setup will be fixed and also because of heat and power consideration. Pls wat do u think?
    Temitope Amoo replied 14 years ago 3 Members · 4 Replies
  • Dennis Size
    September 29, 2012 at 5:09 pm
    I think you should not worry about lighting a room and instead light for the people, event, or subject you’re shooting IN that room.
    You have 3 lights. It appears to be fait accompli the way you’ve presented it.
    You’ve already decided what you’re doing. You said your PAR was your backlight; then your 2 Kino’s must be some combination of sidelight and frontlight.
    By the way, there’s no law that says one of your Kinos couldn’t be your backlight — and your PAR the Keylight.
    Don’t “paint yourself into the corner” of your 16’x 16′ space.
    DS
  • Temitope Amoo
    September 29, 2012 at 5:14 pm
    Thanks. I need the room well lit because an individaul paces to and from. Its more of a stage set up. So I was wondering if the individual will b well lit irrespective of where he is in the room.
  • John Sharaf
    September 29, 2012 at 5:15 pm
    Temitope,
    I had exactly the same reaction as Dennis when I saw your title line; you don’t light a room (unless it’s for a real estate advert or architectural magazine) you light the people “in the room”.
    I also agree with Dennis (great minds think alike!) that the PAR could make an excellent key light; two old-school techniques are either through a hanging “shower curtain” or dangling roll of heavy white diffusion like Lee 216, or even bounced off a 4×4 foamcore. Then use the Kinos for backlight and fill (if necessary).
    JS
  • Temitope Amoo
    September 29, 2012 at 5:26 pm
    Oops! I need to add that the lights will b hung on the wall. So is this set up bright enough for…let’s say…an interview session?
