Activity › Forums › Apple Final Cut Pro Legacy › lighting issues as was rushed with set up and noise is visible: https://www.youtube.com/watch?v=73-S6IU0OQg&feature=youtu.be
  • lighting issues as was rushed with set up and noise is visible: https://www.youtube.com/watch?v=73-S6IU0OQg&feature=youtu.be
    Posted by Jay James on September 11, 2013 at 11:34 am
    Hello
    shot the interview yesterday and was rushed with the setup used an LED that I attached to my camera for additional lighting – can’t afford to lose this footage as won’t be able to do this interview again- do you think I can get away with how it looks now or is it a write off or can anyone suggest a way of improving it.
    did put a face light filter on it
    Please ignore sound it was recorded on an H4N, and will be synced up
    Advice would be greatly appreciated
    Thanks in advance
    Here is a link to the footage: https://www.youtube.com/watch?v=73-S6IU0OQg&feature=youtu.be
    Mark Suszko replied 13 years ago 3 Members · 4 Replies
  • John Fishback
    September 11, 2013 at 1:54 pm
    Neat Video does an excellent job with noise-also Innobits’ Video Purifier.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.7.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.7, Motion 5.0.6, Compressor 4.0.6
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
  • Mark Suszko
    September 11, 2013 at 4:16 pm
    The blown-out background contrast can be made a little easier on the eyes by layering two or more identical video tracks, adjusting the highs, lows and mids in each, then adjusting the opacity and blend modes in-between the layers. You can also use a multipoint mask tool around his head and shoulders to separate him from the BH and allow separate adjustments. Are you any goo with the 3-way color corrector in FCP7? How about Apple Color?
  • Jay James
    September 11, 2013 at 7:33 pm
    Thanks for your response John & Mark will go with Marks suggestion as bit low on funds at the moment – I shall put your advice into action Mark – the mask tool? what is that called within FCP is it under matte? or is it a plugin that I have to download? I’m pretty clued up with Colour Correction
    Jay
  • Mark Suszko
    September 11, 2013 at 10:28 pm
    Search for “Paul Crisp multipoint masking tool free.” and you should come up with 8,16,and 32-point versions of the 4-point masking tool.
