Activity Forums Maxon Cinema 4D Lighting Interiors
  • Lighting Interiors
    Posted by Jared Benson on July 14, 2014 at 2:53 pm
    Kind of a newb here and I have a very detailed model that I am working on. I am trying to make a cross section of it, using near clipping on the camera but none of my light sources will illuminate the interior. I’m using an older model IMAC so using a boole object actually freezes C4D. Is there any way to get good lighting in the interior or a model like this when using near clipping on the camera?
    Adam Trachtenberg replied 12 years, 1 month ago 3 Members · 2 Replies
  • Darby Edelen
    July 14, 2014 at 3:13 pm
    Clipping planes on the camera do not actually remove geometry before the shading stage of rendering.
    You have to modify the geometry either through a boolean operation or by cutting and removing geometry.
    If the Boole generator is too slow you could try rBoole (render time boolean).
    https://plugins4cinema4d.com/rboole.html
    Darby Edelen
  • Adam Trachtenberg
    July 14, 2014 at 3:32 pm
    I suggest you try the rboole plugin here: https://plugins4cinema4d.com/rboole.html
    Setup is little tricky but it works well once you get the hang of it.
