Light Tracking in Psunami with Bobbing On?
I was trying to learn psunami, after effects.I set the scene and bobbing surface to around 7.I am trying to track the lens flare to the sun.
I have heard lens flare pro tracks alpha but it is not available for 32 bit xp SP3.I tried manual tracking in the AE lens flare and bcc lens flare.
I am trying to track ‘light source’ in psunami.
Now the problem is that both the tracking methods I try work fine, until the sun/white light point goes out of the frame, as the bobbing is turned on.And when the sun comes back into the seen, the tracker is already lost and can’t resume.
How should I deal with this?
Am I doing anything wrong?Thanks.
