Activity Forums Adobe After Effects Expressions Light Sweep Effect Boundaries.
  • Light Sweep Effect Boundaries.
    Posted by Jace Bradley on January 17, 2023 at 10:10 pm
    Hi wonderful people.
    I am trying to create a script to animate the Center Property for the CC Light Sweep Effect so it will animate from left to right but based on layer boundaries. I tried to just add normal keyframes but that doesn’t work.
    this is the code :
    myButton2.onClick = function() {
    app.beginUndoGroup(“UNDO SWEEP”);
    var activeComp = app.project.activeItem;
    if (!(activeComp instanceof CompItem)) {
    alert(“Please select a layer in the active composition.”);
    return;
    // Get the selected layers
    var selectedLayers = activeComp.selectedLayers;
    if (selectedLayers.length == 0) {
    alert(“Please select at least one layer.”);
    return;
    for (var i = 0; i < selectedLayers.length; i++) {
    var currentLayer = selectedLayers[i];
    // Add the Light Sweep effect to the layer
    currentLayer.property(“Effects”).addProperty(“CC Light Sweep”);
    // Get the layer boundaries
    var left = currentLayer.sourceRectAtTime(0, false).left;
    var right = currentLayer.sourceRectAtTime(0, false).right;
    // Set the current time indicator as the starting point for the animation
    var currentTime = activeComp.time;
    // Get the “center” property of the effect
    var center = currentLayer.property(“Effects”).property(“CC Light Sweep”).property(“Center”);
    // Animate the “center” property from left to right over a duration of one second
    center.setValueAtTime(currentTime, [left, 0]);
    center.setValueAtTime(currentTime + 1, [right, 0]);
    center.setInterpolationTypeAtKey(1,KeyframeInterpolationType.BEZIER, KeyframeInterpolationType.BEZIER);
    app.endUndoGroup();
    // Show the UI panel
    myPanel.show();
    That is setting two keyframes but is not animating at all 🙁
    Thank you in Advance.
    Jace Bradley replied 3 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
