Activity › Forums › Apple Final Cut Pro Legacy › light strikes effect
Posted by Giuliano Bausano on April 24, 2012 at 2:25 pmGiuliano Bausano replied 14 years, 5 months ago 2 Members · 2 Replies -
Jeff Meyer
April 24, 2012 at 4:52 pmMotion has a lens flare generator, but it’s pretty basic. For the look you’re wanting, the built in lens flare generator won’t cut it. If I remember correctly it doesn’t even have transparency, so you’ll need to use composite modes or a luma keyer to have it appear over the video. Also, if you do go with the built-in generator make sure you animate the lens flare’s origin, not its x/y position.
This Motion plugin appears up to the task, but I haven’t used it.
https://www.motionvfx.com/mplugs-1.htmlIf you have After Effects I can give a strong recommendation to Video CoPilot’s Optical Flares plugin.
https://www.videocopilot.net/products/opticalflares/ -
Giuliano Bausano
April 24, 2012 at 6:09 pmthanks a lot for the answers,
i tought it was optical flares in AEFX but i supposed there is a plug-in which “pump” the light i already got in the scene..lens flare gave me different results and, also, had to be animated 🙂
Giuliano.
