Activity Forums Maxon Cinema 4D Light Pulses up and down a cloned object
  • Light Pulses up and down a cloned object
    Posted by Christian Roman on October 25, 2016 at 7:09 pm
    I’m trying to get pulses of light traveling up and down a circular cloned object. So light travels down and up each ring starting from the smallest center to ring to the outermost ring with the largest radius. I tried by animating a circular gradient on a luminance and then applying this to the alpha channel on my object. However its not having the intended effect. Any help would be appreciated.
    10731_lightpulse.c4d.zip
    Christian Roman replied 9 years, 11 months ago 2 Members · 4 Replies
  • Adam Trachtenberg
    October 25, 2016 at 8:30 pm
    Does this work for you? 10732_10731lightpulseamt.c4d.zip
  • Christian Roman
    October 26, 2016 at 12:12 am
    Yes is exactly it. If I wanted to change the color of the clones and add more pulses do I just group everything and duplicate? Thanks so much.
  • Adam Trachtenberg
    October 26, 2016 at 3:25 am
    You can change the color using Shader Effector’s gradient controls. You’d add more pulses the same way (by adding more knots).
  • Christian Roman
    October 26, 2016 at 4:34 pm
    Ahhh I see now. The powers of the gradient. Thanks so much.
