Activity Forums Adobe After Effects Expressions Light positions using Corner Pin?
  • Light positions using Corner Pin?
    Posted by Adam Taylor on July 24, 2014 at 10:59 am
    I have a null with corner pin data from Mocha and i want to use this data to position four Lights, one at each corner.
    It works but only partially, and i am unclear how to solve it.
    The problem seems to be that when i pickwhip the corner pin data, The 2d position gets transformed into 3d on the Light, with the z position just duplicating the y position. This ends up hiding the Light behind all the layers!
    i cannot figure out how to replace this 3rd dimension with a fixed point. Every thing i try just throws up errors.
    Is this even possible? and if so, how?
    thanks
    Adam
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
    My YouTube Animations Page
    Tom Holmes replied 12 years, 1 month ago 3 Members · 3 Replies
  • Dan Ebberts
    July 24, 2014 at 4:18 pm
    Maybe you just need to stick your pickwhipped value into a variable and only use the x and y, like this:
    temp = (your pickwhipped value goes here);
    [temp[0],temp[1],value[2]]
    Instead of value[2], you could also substitute any z value you want.
    Dan
  • Tom Holmes
    July 24, 2014 at 4:19 pm
    Hi Adam,
    You will need to put this as an array,
    Try this:
    Drop down the position of the first light (hit ‘p’) Alt-click on the stopwatch to open expression editor. type ‘[‘ and then pickwhip the X value for the corner you want this light to be attached to, then type ‘,’ and pickwhip the Y value for the same point, then add another comma and then pickwhip to the lights own Z value (this will allow it to be adjusted)
    The position expression of the light should then look something like this (with your layer/effect names):
    [thisComp.layer(“Adjustment Layer 1”).effect(“Corner Pin”)(“Upper Left”)[0],thisComp.layer(“Adjustment Layer 1”).effect(“Corner Pin”)(“Upper Left”)[1],transform.position[2]]
    Repeat this step for each light to each other the other points.
    then set the Z value for each of the lights depending on how far forward in Z space you want them.
    I hope this helps!
    Tom
    [thisComp.layer("Adjustment Layer 1").effect("Corner Pin")("Upper Left")[0],thisComp.layer("Adjustment Layer 1").effect("Corner Pin")("Upper Left")[1],transform.position[2]]
  • Tom Holmes
    July 24, 2014 at 4:21 pm
    Dan you beat me to it haha,
    Adam don’t listen to me when Dan’s about haha…
    I still need your help on my expression issue Dan! 🙂
    Tom
