Activity Forums Adobe After Effects Expressions Light Intensity based on composition’s width & height
  • Light Intensity based on composition’s width & height
    Posted by Seth Minnich on June 8, 2023 at 2:20 pm
    Hi all,
    I’m hoping someone could help me out. I’ve been trying to figure out how to write an expression for a Point Light to have “dynamic edge triggering” – similar to Optical Flares’ edge of frame light brightening but inverted. This is close to what I want to do but I’m not using a camera and I’m using a light instead of a layers (https://www.youtube.com/watch?v=I-Acdl_l9G0&t=15s).
    What I’m trying to do is have a Point Light’s Intensity go from 0% once it hits the edge of the comp/stage edge to 100% Intensity at the center of the comp/stage. Ideally if the comp size changed, everything would still work the same without having to update the comp dimensions in the expression.
    Brie Clayton replied 3 years, 3 months ago 3 Members · 3 Replies
  • Dan Ebberts
    June 8, 2023 at 3:43 pm
    Something close to this maybe:
    p = toComp([0,0,0]);
    w = thisComp.width/2;
    h = thisComp.height/2;
    center = [w,h];
    maxD = Math.sqrt(w*w + h*h);
    d = length([p[0],p[1]],center);
    easeIn(d,0,maxD,100,0)
  • Seth Minnich
    June 8, 2023 at 5:59 pm
    Awesome, thanks Dan this works exactly how I hoped. I appreciate the fast help!
  • Brie Clayton
    June 11, 2023 at 3:15 am
    Thanks for your solve, Dan!
