Activity › Forums › Adobe After Effects › Light Factory : Visible in AE but not on Renders!
  • Light Factory : Visible in AE but not on Renders!
    Posted by Anderson Jones on June 26, 2009 at 4:02 pm
    I’ve running AE CS3 and Knoll Light Factory2.5 for a year+ and have never encountered this issue.
    Everything was rendering fine on the job, flares visible etc for a week. I’m using LF Glow I have UnMult installed. Its all good.
    Then as of 6:00 yesterday… Working in AE i can see nice LF Glows in full res 100% – I can adjust keys, values as usual. Then I render and NO FLARES appear on output frames!
    I know its not some render setting… I’ve tried everything premult, straight – tried Tiffs Targas still no flares. I didn’t install or change anything recently so I’m completely baffled. I have been crashing but no more than usual. Is there a prefs file or something for plug-ins that could have ben corrupted? quicktime update thing i’m using 7.6.2? I guess I’ll try re-installing the plug-in.
    of course this all happens as the project is delivering.
    I was forced to screenshot stills inside Ae and try and recreate everything. Nightmare.
    Anderson Jones replied 17 years, 3 months ago 2 Members · 2 Replies
  • Michael Szalapski
    June 26, 2009 at 4:33 pm
    To quote The IT Crowd, “Have you tried turning it off and on again?” Also, since you’re talking about crashes I’ll assume it’s a Windows machine, if you hold Alt + Ctrl + Shift while AE’s starting up you can trash the preferences file. It’ll rebuild a default one…that fixes a lot of issues. (It also means you’ll have to redo any changes you’ve made as far as preferences go…)
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Anderson Jones
    June 26, 2009 at 4:49 pm
    I’m actually on mac- just reinstalled knoll LF and it IS showing up in renders again-
    Not 100% sure but I think the problem was i was working off an auto-save project file-
    that may have been corrupted after a AE crash. AE is still not rendering original plug-in layers but if i apply the same effect to new layers the effect does render.
