Activity › Forums › Avid Media Composer › Lift without marking IN and OUT points?
Posted by Naveen Mallikarjuna on June 1, 2015 at 3:16 pmIs there a way to Lift a clip without having to mark in and out points?
If I select a clip and use the Forward Delete button (on a Mac), the clip is Extracted (so all subsequent clips ripple backwards).
I’d like to just remove the clip without rippling the timeline (i.e. Lift), but I don’t see a way to do that without marking in and outs.
MC6.5.2 OSX 10.10.2
Naveen
Job Ter burg replied 11 years, 4 months ago 5 Members · 7 Replies -
Daniel Frome
June 1, 2015 at 4:57 pmEverything ripples back because you have the yellow arrow (extract/splice) activated on the smart tool.
If you only activate the red arrow (lift/overwrite) and do the same thing, the clip will remove without changing the rest of the timeline.
Shane Ross
June 1, 2015 at 5:21 pmSelect the clip and press the regular DELETE key…that’ll lift it. But, if there are effects on it…it’ll clear those first. meaning you might have to select and delete it twice….as the first delete deletes the effects
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Naveen Mallikarjuna
June 1, 2015 at 7:17 pmShane – Actually meant to put this in my original post, but both delete keys (“delete” which is the equivalent of “backspace” on a pc, and “delete forward”) produce the same result.
Daniel’s suggestion did the trick. (Thanks Daniel!)
That said, it’s a bit frustrating having to deselect the Extract function first. Wish it worked as Shane mentioned.
Though marking an in and out with the shortcut and then lifting isn’t bad. Problem is this only works for one clip, not multiple.
Naveen
Shane Ross
June 1, 2015 at 10:08 pmOdd. Doesn’t work that way for me. And I’m on a mac.
Shane
Little Frog Post
Naveen Mallikarjuna
June 1, 2015 at 10:37 pmAnother random shortcut that should work does not work for me as well. Possible because I am on 6.5.2.
I was told to upgrade to 6.5.4 but that has proven problematic since I’m on Yosemite, and there is an uninstall issue. Will have to do when there’s a lull in the work.
Naveen
John Pale
June 2, 2015 at 5:48 pmIf you can live with quickly placing an in/out around the clip, all you have to do is press “T” to put marks around the clip, then “Z” to lift. Takes about a second.
Job Ter burg
June 3, 2015 at 6:57 amRed segment select the clip, hit ctrl-x (pc) or cmd-x (mac). That’s Power Delete, takes out the clip and any effects applied to it in one go.
