  • Posted by Gordon Gurley on October 24, 2006 at 4:48 pm
    When lifting a clip from a sequence, FCP hangs for 30-60 seconds (spinning beach ball). It eventually rights itself and I can continue working. All other edit functions behave normally. Other projects don’t have this problem. Any idea what the problem may be?
    Sequence: HDV
    media: about 15 hours of HDV and DV
    FCP 5.04
    Dual 2.3 G5
    2Gigs RAM
    Kona SD
    Xserve RAID
    Gordon Gurley
    Director of Operations
    Stanford Video
    Gordon Gurley replied 19 years, 10 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    October 24, 2006 at 5:55 pm
    Sounds like you’re running out of RAM… and a disk caching is causing the slow down… Could be something else I suppose, are you mixing the two formats in the same sequence? what is the sequence setting?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Gordon Gurley
    October 24, 2006 at 6:02 pm
    RAM was my first guess, but Activity Monitor shows at least 500 Meg of RAM headroom at all times. I have plenty of room on my root drive for VM. Sequence settings are 1080i HDV. I am mixing a little bit of DV in with my HDV show.
    Gordon Gurley
    Stanford Video
