Activity Forums Maxon Cinema 4D License Plate
  • License Plate
    Posted by Tom Slattery on December 11, 2008 at 2:37 pm
    Hi!
    I’m wonder how best to achieve the pressed-metal effect like how license plates are made. Is there a way to take say, 3D text, and push it into the back of a plane, where the other side comes out with rounded edges?
    ~TPS
    Tom Slattery replied 17 years, 8 months ago 3 Members · 3 Replies
  • Randy Johnson
    December 11, 2008 at 2:58 pm
    The best way is sub poly displacement You need Advanced render module though. If you have AR its the last option in the material editor.
    If that wont work for you model it with a hyper nurbs and use weighting to get the right curves.
    here is an example. I have not done any weighting to the edges.
    http://www.randyarchy.com/pressed.c4d.zip
    /Randy
  • Adam Trachtenberg
    December 11, 2008 at 4:16 pm
    For a flat object like a license plate you can actually use the old relief object, so AR wouldn’t be necessary.
  • Tom Slattery
    December 11, 2008 at 4:25 pm
    The Relief is exactly what I was looking for.
    ~TPS
