Activity Forums Apple Final Cut Pro Library will not open after Final Cut Pro update
  • Library will not open after Final Cut Pro update
    Posted by Su jeong Kang on March 29, 2019 at 6:04 am
    This time, I have Final Cut Pro X updated the version 10.4.6.
    When I opened the library after the update,
    I received a message that I should convert the png file into mov,
    so I converted it.
    Since then, the library won’t open and it keeps turning off.
    If I try to open a library from an old version of Final Cut, I can’t open it because it’s an updated library.
    The backed up library also won’t open because the library won’t open.
    It’s a library I’m working on, so it’s really important.
    Is there any way?
    I could try many ways
    But same.
    Please reply.
    Thank you.
    Su jeong Kang replied 7 years, 5 months ago 2 Members · 2 Replies
  • Ronny Courtens
    March 30, 2019 at 6:02 pm
    I have never seen FCP X ask me to convert a PNG file to a .mov video file when updating a Library, that even does not make sense.
    To be clear:
    1. You opened the Library, it asked you to update the Library to the newest version and then you got this strange message, is that correct?
    2. You say you converted a PNG file to MOV. Where was that PNG file, and how did you convert it to MOV?
    3. What did you do with the MOV file after the conversion?
    – Ronny
  • Su jeong Kang
    April 1, 2019 at 4:26 am
    Strangely enough, I got a message that I would convert ‘png’ into ‘mov’.
    I think it’s because we didn’t import the png file and we dragged it into the project.
    After trying many ways to open library on the Internet, I saved the library.
    It’s not perfect, but it’s not hard to work.
    I don’t think there are many, but I write down the methods I used for people with problems like myself.
    1.I’m going to look at the hidden files in the library.
    2.Delete the currentversion.flexible.
    3.I opened it in the final cut X of the version before the update
    ->Although it damaged, I finally opened the library.
    4.I opened the backed up library, exported it to the xml of each project.
    5.I created a new library, and saved it.
    Thank you Ronny for answering my question.
