Activity › Forums › Apple Final Cut Pro › Library not showing up
Posted by Steve Connor on April 9, 2014 at 7:29 amWhen I open FCPX I load a library and get the progress box open up to say it’s loading it but it never shows up in the libraries pane. Have done the usual trash prefs etc with no improvement. Any ideas?
I’m getting concerned as this is my main library!
Steve Connor
Class Bully
Steve Connor replied 12 years, 5 months ago 5 Members · 17 Replies -
Steve Connor
April 9, 2014 at 12:39 pmI can now get it to load if it’s the only library open, but it’s lost all the projects, there’s also a second library affected as well, have tried everything including backups but there’s still a problem.
Not a happy FCPX user at the moment
Steve Connor
Class Bully
Jeremy Garchow
April 9, 2014 at 3:44 pmWhere are they located? Boot drive or external? have you checked permissions?
Loren Risker
April 9, 2014 at 6:13 pmTry copying the library to back it up, then right click it and show package contents. Does it look like your libraries are in there?
OutOfFocus.TV – Original series, music videos, mini-docs. -
Steve Connor
April 9, 2014 at 6:18 pmThanks, It’s an external SATS RAID I’ve tried both of those and it doesn’t work. The library now shows up but there are projects missing from some of the events in it.
It’s a strange one.
Steve Connor
Class Bully
Charlie Austin
April 9, 2014 at 6:21 pm[Steve Connor] “The library now shows up but there are projects missing from some of the events in it. “
So the actual project Folders are missing from the Library when you open the package in the finder? That is weird. Do you use that Library Manager app or anything like it?
~ My FCPX Babbling blog ~
~”It is a poor craftsman who blames his tools.”~
~”The function you just attempted is not yet implemented”~ -
Steve Connor
April 9, 2014 at 7:19 pm[Charlie Austin] “So the actual project Folders are missing from the Library when you open the package in the finder? That is weird. Do you use that Library Manager app or anything like it?
“No I don’t, also the events and projects that are missing actually show up in the package contents, they just don’t show up in FCPX!
Steve Connor
Class Bully
Jeremy Garchow
April 9, 2014 at 7:20 pm[Steve Connor] “No I don’t, also the events and projects that are missing actually show up in the package contents, they just don’t show up in FCPX!”
Did you at any time move those Projects from another Library via the Finder?
Jeremy Garchow
April 9, 2014 at 7:23 pm -
Charlie Austin
April 9, 2014 at 7:25 pm[Steve Connor] “No I don’t, also the events and projects that are missing actually show up in the package contents, they just don’t show up in FCPX!”
So, somehow or other, it sounds like the Library database (CurrentVersion.flexolibrary) got hosed… I know it’s not much help, but if you can somehow contact apple support I’ve heard they have been able to fix things like that. Though it could jet be a Rumor…
You said even the backups exhibit this? Are these the FCP auto backups or physical backups you have?
