Activity Forums Apple Final Cut Pro Library not showing up
  • Steve Connor
    April 9, 2014 at 7:42 pm
    [Charlie Austin] “You said even the backups exhibit this? Are these the FCP auto backups or physical backups you have?
    Auto, I didn’t have physical on these two libraries! I’ll contact support tomorrow, I’m hopeful there’s a fix as everything is still in place.
    Steve Connor
    Class Bully
  • Steve Connor
    April 9, 2014 at 7:43 pm
    [Jeremy Garchow] “Did you see this?
    https://forums.creativecow.net/thread/344/2943
    That IS a good catch, but it doesn’t help my problem sadly!
    Steve Connor
    Class Bully
  • Steve Connor
    April 9, 2014 at 7:52 pm
    Also every time I open one of the corrupted projects I get the “restoring window layout” issue when I try to re-open FCPX
    Steve Connor
    Class Bully
  • Charlie Austin
    April 9, 2014 at 7:54 pm
    [Steve Connor] “Auto, I didn’t have physical on these two libraries! I’ll contact support tomorrow, I’m hopeful there’s a fix as everything is still in place.”
    Bummer, Hopefully someone there can help. Like you said, the data appears to be there so…
    Also, FWIW, If you don’t have it, Backups for Final Cut Pro has saved my ass a couple times. Keep us posted…
    ~ My FCPX Babbling blog ~
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
  • Charlie Austin
    April 9, 2014 at 7:58 pm
    [Steve Connor] “Also every time I open one of the corrupted projects I get the “restoring window layout” issue when I try to re-open FCPX
    You probably did this, but go to your user Library > Application support > Final Cut Pro and trash the “Layouts” folder (after making a copy, I’m crazy like that)…
  • Jon Cairns
    April 10, 2014 at 2:06 pm
    If you open this library in a different User account do you see the same issue?
    I had some odd Library behavior (on quite and relaunch open libraries were closed, closed libraries were open, etc.). Same libraries on same drive behaved fine under a new User.
    It’s not the same issue you are seeing but worth a try?
    Jon
  • Steve Connor
    April 10, 2014 at 8:06 pm
    That’s a good thought, thanks I’ll try it
    Steve Connor
    Class Bully
Page 2 of 2
