Activity › Forums › AJA Video Systems › LH Going back to earlier software from 2.0.1
  • Gary Adcock
    July 28, 2006 at 12:08 am
    [Dave Beaty] “Is it possible to flash back to an ealier version of Kona software. I upgraded to 2.0.1. Now if I try to install 2.0 or before I get a “there is nothing to install” error.”
    did you try doing an uninstall first? ( it is in the aja utilities folder)
    NO software will allow you to install an older version over a newer one.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Chicago, IL
  • Dave Beaty
    July 28, 2006 at 12:57 pm
    Yes, I did a complete uninstall. It may be that 2.0.1 upgrades the board firmware and going back to an earlier version is not possible?
    Some installers have an optional key sequence that will allow a back slush of the firmware. I’m going to call TS today to see what’s up with my system as the audio output is bad. I may try some of the earlier installers. As it is now, only 2.0.1 will reinstall. (after an uninstall).
    Dave Beaty
    Dave Beaty
    Dreamtime Entertainment
    3613 Del Prado Blvd.
    Suite 202
    Cape Coral FL 33904
    239-549-4081
    800-446-7575
    dave@dreamtimeentertainment.com
    http://www.dreamtimeentertainment.com
  • Ron Thompson
    July 30, 2006 at 11:59 am
    I had this after installing some versions of KonaLH software. A good round of permission repairs and preference trashing should help.
    Ron
  • Ben Cheng
    August 1, 2006 at 5:44 am
    Hi All,
    I corresponded with AJA Support on this issue & here’s their reply:
    “In regards to the driver install: Before you install any Kona driver, go to:/library/receipts and delete all the AJA Kona pkg files.”
    Hope this helps.
    Cheers,
    Ben Cheng
    The Media Village
    Singapore
