Activity Forums Live Events & Streaming LG W2243T out of range with A/V Switcher
  • LG W2243T out of range with A/V Switcher
    Posted by Duane Cabot on June 8, 2013 at 3:42 pm
    Hi, I have a LG Flatron W2243T monitor that I want to use as a multiview display with my a/v switcher (sony MCS-8M). When I plug it via a DVI cable I get a ”out of range 33.6 / 30 hz” message. I can’t change settings on the DVI out put of my switcher…what can I do?
    Nick Ring replied 12 years, 10 months ago 3 Members · 2 Replies
  • Phil Senger
    June 20, 2013 at 9:20 pm
    I don’t have a definitive answer, only a suggestion.
    Try using a DVI -> HDMI cable, DVI out of the switcher, HDMI into the monitor
    Phil Senger
    SW Audio+Visual
    Vancouver, BC
    http://www.sw-online.com
  • Nick Ring
    November 5, 2013 at 5:45 pm
    Replying for a bit of future reference.
    I just encountered the same problem with an LG 2242T and an Acer monitor as well (which gave me less info). I did find out that if I set the MCS-8M to 720 instead of 1080, then the monitors will recognize it. Obviously not ideal. In any event, I’ve only been playing with it for an hour, so when I find out more, I will post it here.
    Next, on to getting my MBP and the DVI in to work.
