Activity › Forums › Apple Final Cut Pro Legacy › Level changes during transition
  • Level changes during transition
    Posted by Richard Marsh on June 16, 2009 at 11:31 pm
    I have two graphics that are keyed over a background movie. They are nearly identical. The first graphic is a syringe that appears to be filled with a blue substance. The graphic I am trying to wipe to is exactly the same, except there is no blue. The wipe effect creates an animated look, as thought the syringe is injecting. Simple. The problem is, during playback and after a render, the levels shift (brighten), stay there for the duration of the wipe (60 frames), then shift back to normal.
    I’m not sure what to try next. Anyone have any suggestions?
    Richard Marsh replied 17 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
