Activity Forums Apple Final Cut Pro Legacy Letterboxing Top and Bottom in DVD Studio Pro
  • Letterboxing Top and Bottom in DVD Studio Pro
    Posted by Frank Giardina on July 29, 2010 at 9:48 am
    Hi…
    I’m working with FCP 7, shooting with Canon 7D and a Canon XH A1s. Here’s my Sequence Settings.
    Time Base: 29.97fps
    Frame Rate: 1440 x 1080
    Aspect Ratio: 1440 x 1080 (16:9)
    Field Dominance: None <— is that OK?
    QuickTime Compressor Settings: 422(LT)
    I’ve tried sending to Compressor and Playing out a QuickTime current settings, then going to Compressor for my mpe2 and audio, and in both cases when I go to DVD Pro and author a DVD I’m getting letterboxing Top and Bottom. I’ve checked and double checked to make sure I didn’t flag anything as letterbox, but I’m still getting it. It’s minor when I play the DVD on my computer, and varies a little on a couple different wide screen TVs.
    It’s making me crazy!
    HELP! 🙂
    Frank
    Frank Giardina replied 16 years, 2 months ago 2 Members · 2 Replies
  • Chris Tompkins
    July 29, 2010 at 2:49 pm
    Frank ur shooting and editing in 16 by 9
    You want letterbox on a SD DVD.
    If Not?
    Output Sequence current settings ref file.
    Drop into compressor.
    Choose a 4X3 option in the settings. This makes a 4X3 mpeg not a widescreen.
    Then bring into DVDSP.
    Chris Tompkins
    Video Atlanta
  • Frank Giardina
    July 29, 2010 at 3:07 pm
    Hi Chris…
    Yes, shooting 16:9 on a Canon XH A1s and Canon 7D … I’m 1440 x 1080. I’ll try the 4:3… last year when I was 720 x 480 anomorphic that worked.
    Here’s my sequence setting, clip based
    Time Base: 29.97fps
    Frame Rate: 1440 x 1080 (16:9)
    Field Dominance set to none <— note sure if this is right given I have mixed media
    QuickTime Compressor setting: 422 (LT)
    Frank
    Frank
