Activity Forums Adobe Premiere Pro letterboxing 16×9
  • letterboxing 16×9
    Posted by Kent Smith on June 24, 2005 at 5:46 pm
    I shot a project in super 16, and transfered it to digibeta with a dvcom slave, both versions in anamorphic 16×9. I’m cutting with the dvcam footage for off line, then will online the digibeta. ONe question. Everyting works fine if I have a 16×9 monitor, but if I want to make a dvd screener from the offline, I can’t find a setting to letterbox it in a 4×3 frame. All I get is more squeezed and more squeezed. Anyone got an idea?
    Kent Smith replied 21 years, 3 months ago 2 Members · 2 Replies
  • Jay Lee
    June 24, 2005 at 10:37 pm
    Kent
    Import your 16×9 (1.2 Pixel Aspect Ratio) comp into a 4:3 (0.9 PAR) comp and reduce the footage size/scale by 75%. You will need to render to output but if your going to DVD your will need to render to MPEG-2 regardless.
    Cheers,
    J
  • Kent Smith
    June 25, 2005 at 7:12 am
    thanks, i’ll give it a shot, and see how it goes.
    kent
