Activity Forums AJA Video Systems Letterbox with IO LA ?
  • Letterbox with IO LA ?
    Posted by Bob on December 7, 2005 at 7:14 pm
    I have a dv 50 anamorphc timeline, it plays out perfectly on my 16×9 display. What is the best way to output a letterboxed version to tape. I’d rather not have to export a QT and re-compress back into a new project, can I cut a paste. ?
    Bob
    Jeremy Garchow replied 20 years, 9 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    December 7, 2005 at 8:21 pm
    Nest the sequence into a regular (not anamorhoc) 4:3 timeline and it should adjust for you. If not select the nest, hit return (to load it in the viewer), click open the motion tab and twirl down the distort parameter. Change the ‘aspect’ value to -33.33.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
