Activity Forums Apple Final Cut Pro Letterbox + Project Size Questions
  • Letterbox + Project Size Questions
    Posted by Nicolas Vallejo on July 1, 2013 at 11:48 pm
    Going to try and kill two birds with one stone here.
    First: shooting a project with a mix of 1920 X 1080 and 1280 X 720 footage. Final output size will be 1280 X 720. Project size and RAM aren’t a factor. What I care about the most is the quality of the 1280 X 720 footage and how it will look once I export. Does it matter at all which project size I use, or is this just a Compressor thing I should tweak with.
    Second: This same project is a 2.35 project. I’m putting tape on the LCD of a 7D to get 2.35 framing. In terms of post, what will give me THE LEAST LOSS of quality? A 2.35 effect or a 2.35 .png template which I will have to composite. Or is there an advantage to using one or the other?
    Thanks.
    Paul Figgiani replied 13 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • James Cude
    July 2, 2013 at 1:18 am
    I’d edit it at 1920×1080 and export to 720 when you’re done- this is much easier if you have Compressor. Otherwise edit at 720p.
    For the letterbox- use the built-in Letterbox filter, which already has a preset for 2.35.
  • Andy Neil
    July 2, 2013 at 1:19 am
    [Nicolas Vallejo] “Does it matter at all which project size I use, or is this just a Compressor thing I should tweak with.”
    Yes it matters. Make your project size 1280×720. Scaling down 1080 footage is better than scaling 720 footage up (and then scaling back down again).
    [Nicolas Vallejo] “A 2.35 effect or a 2.35 .png template which I will have to composite. Or is there an advantage to using one or the other?”
    Unless the .png is smaller than the project size, there won’t be a noticeable difference in the masking of the frame. However, a mask effect is much more adjustable.
    Andy
    https://www.timesavertutorials.com
  • Nicolas Vallejo
    July 2, 2013 at 1:22 am
    [Andy Neil] “Unless the .png is smaller than the project size, there won’t be a noticeable difference in the masking of the frame. However, a mask effect is much more adjustable.”
    Also, a problem I forgot to mention when using the letterbox effect – is that you can’t make adjustments on the footage that doesn’t affect the letterbox. So, for example, if I want to scale some footage, that will affect the letterbox as well. Unless there’s something I do not know of, this can’t be adjusted.
  • Nicolas Vallejo
    July 2, 2013 at 1:25 am
    [Andy Neil]
    I already started editing at 1920/1080. Can I just change the project settings to 720p?
  • Andy Neil
    July 2, 2013 at 3:13 am
    If you’re scaling footage then you need to apply the letterbox effect to an adjustment layer above the other layers, or create a Motion generator effect that you can connect above all the other clips, similar to how you’d composite a png. The difference would be your ability to make changes to the amount of masking and the feather and the color after the fact. If you’re using a png, you’d have to recreate it in another program and reimport.
    Regarding your other question, you can change the frame size, but you’re locked into your frame rate unless you create a new project and then copy/paste the clips from one to the other.
    Andy
  • Nicolas Vallejo
    July 2, 2013 at 4:10 am
    Very helpful. Thanks.
  • Paul Figgiani
    July 2, 2013 at 11:46 am
    Nicolas,
    Have a look at the Cinemascope Toolkit plugin that I built for FCPX.
    -paul.
