Activity Forums Apple Final Cut Pro Letterbox option not showing up in the Inspector in order to make 2:35 change
  • Letterbox option not showing up in the Inspector in order to make 2:35 change
    Posted by Scott Herriott on August 15, 2022 at 9:12 pm
    Hey there…
    I highlight all the clips in the timeline, drop the Letterbox effect on them and I see that the aspect ratio has indeed changed a tiny bit. However, unlike the FCPX tutorials I’ve seen online, in the upper right hand area of the FCPX program NO box showing “Letterbox” shows up so I can access the dropdown menu to change it to 2:35.
    Any help would be appreciated.
    I’m running FCPX 10.4.6 on my IMac which is running Mojave 10.14.6.
    Scott
    Scott Herriott replied 4 years ago 1 Member · 0 Replies
  • 0 Replies
