Activity Forums Panasonic Cameras let me ask this another way than ! firestore fs100 quicktime
  • let me ask this another way than ! firestore fs100 quicktime
    Posted by Arty Gold on November 12, 2007 at 6:47 pm
    i did some testing this weekend on our new hvx200 with the firestore 100
    i recorded right to quicktime…
    upon export i get a quicktime file that has 4 audio tracks !
    is this correct /
    i also had to render the file which i believe is wrong ? i need to set my timeline up correctly in order for this to work without rendering?
    Christopher Wright replied 18 years, 6 months ago 2 Members · 3 Replies
  • Christopher Wright
    November 12, 2007 at 8:11 pm
    Yes, you will get 4 audio tracks. Be sure to set up either DVCPROHD 59.97 or 23.97 in Easy Setups within FCP (whichever format you shot in)and you should be able to import your Quicktime clips directly into FCP and edit and playback in RT without any problems whatsoever.
  • Arty Gold
    November 13, 2007 at 12:41 pm
    oh man i think i’m just getting this…
    so with the hvx200 i will essentially no longer be editing in a 29.97 timeline at all ?
    i will either decide to shoot in 480/60 or a 59.97 timeline
    or hd (dvcpro) which is 23.98 ?
    i think this would solve alot of my confusion if this is correct ha !
    thanks for getting back
    November 14, 2007 at 5:22 am
    There are several presets you can use for either 29.97 or 23.97 in both SD and HD with the Firetsore and the HVX-200. Just make sure whatever you use, you match your camera set-up with the appropriate Easy Setup within FCP.
