Activity › Forums › Adobe After Effects Expressions › Less exact motion stabilize?
  • Joe Chao
    April 24, 2005 at 3:19 am
    How about make it by the wiggler?I think the wiggle tool can make the tracked motion less exact.
  • Patryk Rebisz
    April 24, 2005 at 4:27 am
    the wiggler worked!
  • Filip Vandueren
    April 24, 2005 at 5:58 pm
    Hi Patryk,
    the downside of using the wiggler is that it will introduce a different random motion, instead of a bit of your original camera shake,
    If that’s not what you want, try this:
    after you’ve stabilized the shot add this expression to the Position-parameter:
    precision= 50; // use a percentage from 0-100 % ,
    position= ( value*precision + anchorPoint*(100-precision))/100 ;
  • Patryk Rebisz
    April 29, 2005 at 12:08 am
    Filip, what do you mean “Position-parameter”?
    Patryk
  • Filip Vandueren
    April 29, 2005 at 11:43 am
    Hi Patryk,
    Just select the layer you just stabilized, hit the “P”- key and you’ll see the Position-parameter, with any keyframes it might have,
    Then Option-Click on the Timer Icon to the left of the word “Position”, and you’ll see an “=” sign.
    You now have the opportunity to insert an expression (a formula) for the position-parameter.
    This is by default “position”, you’ll see that text highlighted in your timeline, just copy the expression I wrote into that text-field and you’re done.
    See screenshot:
    screenshot of an expression applied to the position parameter
  • Patryk Rebisz
    May 1, 2005 at 11:48 pm
    HUGE thanks!
