Activity Forums Adobe After Effects Expressions Lens Flare position to rotation expression
  • Lens Flare position to rotation expression
    Posted by Chris Standley on June 29, 2009 at 8:11 pm
    Sincere apologies if this has already been covered, but I couldn’t find it anywhere, so I thought I’d ask!
    I’ve built a composition containing a planet and moon built with CC Sphere. I’ve put a lens flare in there as a sun and I want to set an expression so that when I move the lens flare, the angle of the light in CC Sphere matches the position of the sun – just like in the real world.
    Any thoughts?
    Chris
    Dan Ebberts replied 17 years, 2 months ago 2 Members · 3 Replies
  • Dan Ebberts
    June 29, 2009 at 8:49 pm
    Give this a try:
    L = thisComp.layer(“sun”);
    P1 = L.toComp(L.effect(“Lens Flare”)(“Flare Center”));
    P2 = toComp(anchorPoint);
    delta = P1 – P2;
    angle = radiansToDegrees(Math.atan2(delta[1],delta[0])) + 90
    Dan
  • Chris Standley
    June 30, 2009 at 11:11 am
    Mr Ebberts – you are a master.
    Thank you so much for this.
    Now if I could just figure out how the maths actually works….
    Would you mind if I include this in a tutorial I’m doing? I’ll happy say you supplied it.
    Chris
  • Dan Ebberts
    June 30, 2009 at 9:01 pm
    Chris,
    Sure, I have no problem with you including it in a tutorial.
    Dan
