Activity Forums Adobe After Effects Lens flare and radio wave effect covering each other
  • Lens flare and radio wave effect covering each other
    Posted by Tom Batt on December 10, 2015 at 8:30 pm
    I’m trying to have a lens flare streak across view with radio waves pulsing in the background, but each layer covers the other no matter which I put on top.
    Do I have to add the effect to a particular type of layer?
    Any help or a tutorial would be much appreciated. I’m using CS6
    Michael Szalapski replied 10 years, 5 months ago 2 Members · 3 Replies
  • Michael Szalapski
    December 10, 2015 at 10:55 pm
    They should both be applied to solids that are the same size as your composition. The lens flare should be applied to a black solid. The lens flare layer should be set to screen or add blending mode.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Tom Batt
    December 11, 2015 at 7:30 am
    That solved my problem, thanks so much for your help
  • Michael Szalapski
    December 11, 2015 at 2:00 pm
    No problem!
    – The Great Szalam
