Activity Forums Maxon Cinema 4D Length of spline
  • Length of spline
    Posted by Jack Cook on January 29, 2008 at 6:56 pm
    Is there a way to find out what the length of a closed spline is in Cinema 10.5? I mean the distance along the entire spline from beginning to end (which is back at the beginning). I am animating objects along the spline, and I need to animate other objects along other splines of different lengths and match the speeds. This sounds like something that Mograph might do, but I don’t have Mograph.
    thanks,
    Jack
    Mauricio Barrientos replied 2 years, 11 months ago 8 Members · 10 Replies
  • 10 Replies
  • Nolan Scott
    January 29, 2008 at 8:38 pm
    Select your spline (editable) – Top Toolbar – Window / Selection/Structure Info,
    in the Attributes Manager select the Structure-Tab / Spline Length.
    Cheers
    Nolan
  • Jack Cook
    January 29, 2008 at 8:43 pm
    Thank you, Nolan. That’s what I was looking for.
    Jack
  • Gerry Unrau
    May 18, 2012 at 7:50 pm
    Hey There
    Just looking for the method to measure spline length in Cinema 4D R13. Couldnt find anything recent online so just fiddled with it until I found the answer in the depths of the software.
    1/ Highlight your spline in the Object Manager.
    2/ In the Attribute Manager, click and hold on Mode, and Select Project Info.
    3/ Click on the Structure Tab and you will find the Spline Length, as well as the number of Hard, Soft and Split Tangents in your Spline.
    4/ Knowing this can help you find jerkiness in your spline if you are using it as a camera path, for example.
    Hope this helps someone! And Maxon, please add some information to your online help.
    G
  • Abidinsefa Aslan
    July 17, 2012 at 6:07 pm
    Gerry Unrau Thank You. I’ve just crated this account to thank you. I’ve been looking for this all day.
  • Gerry Unrau
    July 17, 2012 at 8:19 pm
    Hey. I’m glad someone could make use of the information. May I ask what you are working on…what kind of C4d stuff do you do?
  • Christelle Bellini
    February 18, 2015 at 11:24 pm
    Hi all, I was wondering in what unit does the length of the spline displays in.
    I tried changing all the units in the preferences but still end up with the same number.
  • Brian Jones
    February 19, 2015 at 3:24 am
    I think it’s the Project Scale units (set in Mode/Project/Project Settings)
  • Mauricio Barrientos
    September 20, 2023 at 2:29 am
    for cinema R23 ?
    how can i measure spline length??
  • George Charoupas
    September 20, 2023 at 5:02 am
    Hello Mauricio,
    You can find the length of a spline here (check my video).
    September 20, 2023 at 3:36 pm
    Thank you …Thanks you a lot
    BLESS !!!!
