Activity Forums Adobe After Effects length of comp & layers
  • length of comp & layers
    Posted by Kurt Murphy on June 13, 2006 at 1:45 pm
    When I brought in a PS file as a comp (in AE7), the comp came in a 2 frames. I don’t see a comp length preference ( there IS a layer length though). When I made the comp 12 seconds, I couldn’t drage or Option] the layer past the original 2 frames… what am I missing?
    thanks,
    kurt murphy
    Mike Clasby replied 20 years, 3 months ago 3 Members · 4 Replies
  • Deadittex
    June 13, 2006 at 2:03 pm
    try pulling the PS layers from the project winfo to the time line after you lengthen the comp… works for me ..
  • Mike Clasby
    June 13, 2006 at 4:25 pm
    Hey, I’m still AE7-less, but in all previous AE’s go to:
    Edit>Preferences>Import
    and under “Still Footage”, click the time one, set to whatever you want for standard, like say 10 seconds (0:00:10:00).
    That should make all your psd Imports as compositions at 10 seconds.
  • Kurt Murphy
    June 13, 2006 at 5:21 pm
    I prefer to have my layers the length of my current comp (which works fine)… It’s the importing of a PS file AS a comp that seems screwy. It comes in at 2 frames – I can change the comp size to 12 seconds, but all the layers within that comp are still 2 frames (which is normal); but I can’t drag out the layers to make them longer, nor can I Option] then using the Timebar (as if they were movie files that lasted 2 frames).
    Anybody else experiencing this?
    thanks,
    kurt murphy
  • Mike Clasby
    June 13, 2006 at 5:36 pm
    Wierd.
    Maybe someone with AE7 can help. or Adobe Support.
