Activity Forums Adobe After Effects Expressions Left aligned text in comp centre
  • Filip Vandueren
    June 29, 2023 at 9:24 am
    Hey Joe,
    since you’re already using 2 layers for the two lines, and the second layer is parented to the first, all you would need is for layer 2 to have this expression for position:
    [thisLayer.parent.sourceRectAtTime().left - thisLayer.sourceRectAtTime().left, value[1]];
    You can still tweak the vertical position of the 2nd line.
  • Joe Blaxland
    June 29, 2023 at 9:43 am
    Thank you very much Filip, works like a charm. 🙂
  • Brie Clayton
    June 29, 2023 at 2:09 pm
    Thank you, Filip, for another fantastic solve!
