Activity › Forums › Apple Final Cut Pro Legacy › LED tv resolutions
  • Jerry Hofmann
    January 12, 2011 at 1:59 pm
    I’m sure the set can receive 720P…. it may upconvert it, but it will work OK. Should also work with SD, but I’ve never seen a very good SD signal on any HD monitor… they all look pretty crunched to me.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Nigel Thompson
    January 12, 2011 at 2:59 pm
    Hey Thanks Jerry
    its strictly for HD signals so that will work, im using a Sony PVM crt for the simultaneous SD monitoring via my kona LHi so im covered.
    HVX200, RED ONE, FCS and more,
    High End, Production & Post Production
    in the Caribbean
    http://www.bistt.com
  • Michael Gissing
    January 13, 2011 at 12:42 am
    Try and turn off as much image processing as possible. I was looking at the Samsung LED LCD’s recently and the “natural motion” made everything look like CGI animation. Also with all that processing you may find audio sync issues as the image may be delayed by enough to make the direct audio from the Kona out of sync.
  • Nigel Thompson
    January 14, 2011 at 11:27 am
    hmmm very true …. what monitor do you suggest then?
    but the clarity of these LEDs are insane
    in the Caribbean
