Activity › Forums › Adobe After Effects › LED display simulator
  • LED display simulator
    Posted by Humble on February 18, 2006 at 9:54 am
    Hi Everyone,
    (This is my first post). I’m looking for an LED simulator I can animate to mimic the scoreboards you get on Pinball machines – so far my searching has turned up nothing – does anybody know if this software exists or if there’s a plug-in for AE?
    Humble
    Blessings you seekers
    Alpay Kasal replied 20 years, 7 months ago 3 Members · 3 Replies
  • Graham Quince
    February 20, 2006 at 7:57 am
    Creating this is pretty easy. Quickest way would be to use CC Ball action I think it’s called and have it break up the display into lots of tiny balls. You can set the scattering to 0, so that they don’t go anywhere.
    Hope that helps
    Graham
    https://www.qcit.co.uk – web design
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
  • Humble
    February 23, 2006 at 9:55 pm
    Cheers Graham, just checked my posts – will get on it and will send you the finished piece when it’s done
  • Alpay Kasal
    March 5, 2006 at 10:38 pm
    another method I’ve used is fractal noise with high contrast, then use mosaic or similar effect to get the shape I want.
    tip: make a seperate comp of JUST the led display, then bring that comp into your video timeline… this way you can make changes to the LED later with ease, and also position/rotate your led display if you need to.
    Alpay Kasal
    Admin/Engineer
    https://www.NYCRenderfarm.com
