Activity › Forums › Adobe After Effects › Learning vectors
  • Learning vectors
    Posted by S. Marcotte on August 6, 2007 at 5:00 pm
    I think the idea is simple enough. I have silhouetted actors in front of a green screen. I’d like to turn this into a vector mask (?) on the assumption that it would let me go in there and grab a few close-ups. They would, of course, remain in silhouette.
    I know nothing about vectors. I’m looking for a short list of key words and concepts; something I can use to get started on my research.
    Any help is appreciated.
    S. Marcotte replied 19 years, 1 month ago 2 Members · 2 Replies
  • Lars Bunch
    August 6, 2007 at 5:52 pm
    Auto trace under the layers menu should get you a good start. Or alternatively, if you have Illustrator CS2 or higher, you could export a tiff sequence and then use Bridge with Illustrator to trace your frames and then re-import them into AE.
    Hope this helps,
    Lars
  • S. Marcotte
    August 6, 2007 at 6:24 pm
    That was far, far too easy.
    Now waiting for the other shoe to drop. Thanks very much.
